Lynne,
It could be that the program is choking when it attempts to do some Access
calls. If your "user" folder is on a network drive and/or if you've set up
the project scratch database file to be non-local (ie. not going to your
"user" folder on your local hard drive but in same folder as the project
"wdp" file and the wdp file is on a network drive), then this might point
to some failure with AcadE trying to run its Microsoft Access calls across
your network. If this is true, and if you have time to test, make the
adjustments to have the project scratch mdb file generated on your local
hard drive and see if the report runs through to the end.
Nate.
"Lint" wrote in message
news:3560374.1083935081214.JavaMail.jive@jiveforum2.autodesk.com...
> Hi, this is my second post on this topic - I need to get a from/2 report
NOW!
> I am trying to run a project-wide from/2 report. I am getting an unhandled
exception at Viawd/wd/wd_mdb.arx at C0000005. Since I am running off the
server, I have two copies of wd_mdb.arx, one local and one on the server.
Renaming them in turn and re-running the reports did not help. I can run the
from/2 report for one drawing from the drawing option, or one drawing from
the project option (with either file renamed or with them both the same
name). I can't report for two drawings.
> What's the problem here?
> Lynne
