Show only
Search instead for
How do I change the Wire Connection Trap distance?
It is currently set to 0.635mm and I cant seem to change it.
I searched the help file and this message board and found nothing.
This wire connection trap distance is a function of the "Feature scale
multiplier" and the three scale factor radio button settings on the drawing
configuration's "Scale Factor" subdialog. It is not a value that can be
changed independently from the others.
Are you having problems with it being too large or too small?
wrote in message news:4947867@discussion.autodesk.com...
