AutoCAD Electrical Forum
Wire Connection Trap
2 REPLIES 2
lkirkup
974 Views, 2 Replies
How do I change the Wire Connection Trap distance?
It is currently set to 0.635mm and I cant seem to change it.
I searched the help file and this message board and found nothing.
2 REPLIES 2
in reply to: lkirkup
This wire connection trap distance is a function of the "Feature scale
multiplier" and the three scale factor radio button settings on the drawing
configuration's "Scale Factor" subdialog. It is not a value that can be
changed independently from the others.
Are you having problems with it being too large or too small?
wrote in message news:4947867@discussion.autodesk.com...
miles.nicholson
Its a converted inch value unfortunately. 2.54/4 = 0.635
Autodesk need to fix this so that its metric or at least the ability to change in the wd.env file or project.wdp
”Boost
