It looks like there is an issue with the project database when you have a
wire with only one segment that goes from one connection on a symbol to
another connection on the same symbol. I have logged this issue. I think if
you split the segment into 2 pieces the annotation will appear correctly.
Again, this seems to be only when wiring between connections on the same
symbol.
Sorry for any inconvenience,
Pat Murnen
wrote in message news:5774195@discussion.autodesk.com...
I am posting the email I sent to Pat here, in case the email doesn't make it
out of our servers.
I put the parent child and footprint all in the same drawing to replicate my
problem (my company won't let me send active project files as the designs
are confidential).
I feel that it may be a database issue. Like I said in the
thread(http://discussion.autodesk.com/thread.jspa?forumID=38&threadID=619284),
when I click on the wire to define wire sequence (verifying that there is a
va
lid connection) it will show both terminals and full device nomenclature.
However, upon running Wire Annotation to Panel Footprint it will output only
one terminal with ?? after it.
Annotation works for terminals from the same direction (IE X1TERM02 to
X1TERM06 to X1TERM10 or (TS1):2 to (TS1):6 to (TS1):10).
Annotation fails for terminals from opposite directions (IE on (PR1)
X8TERM02 to X2TERM07, X8TERM04 to X2TERM09, and X8TERM04 to X2TERM11 or
(PR1):102 to (PR1):107, (PR1):10
4 to (PR1):109, and (PR1):106 to (PR1):111.) Similarly the terminals on
(TS1) have the same problem only it is a X1TERM## to X4TERM##.
I haven't had this problem until AutoCAD 2008 as I have used that 2 current
winding block in many previous projects. I appreciate you taking a look at
this. Hoover looks great, I can't wait to dive into it, I've been really
busy as of late.
Attatchment ACE Error.zip (Includes project files and drawing1.dwg)
