AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
WDP File Inadvertantly Deleted
5 REPLIES 5
rwydesk500
679 Views, 5 Replies
If the WDP file inadvertantly gets deleted from the project folder, is it possible to regenerate a new one?
Rick Yoerger
AutoCAD Electrical 2016
5 REPLIES 5
testsubject
in reply to: rwydesk500
Sorry, Rick.
AFAIK, unless you have a backup, you will have to create it over again from scratch.
Hopefully this will not be too painful for you.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
rwydesk500
in reply to: testsubject
Yikes! That's a backup more valuable than a .BAK file. Smiley Wink
Rick Yoerger
testsubject
You're not kidding since there is no simple way of extracting the drawing descriptions to repopulate the drawing properties part of the WDP.
Bob Hanrahan
Ace User since 1998
Icemanau
Depending on how the file got deleted, you MAY be able to recover it easily.
Check the recylce bin if it is a local file, and you may be able to recover it from there if just the delete key was pressed.
If it was deleted using SHIFT-DEL, you will need to look for and find a recovery program to recover it.
http://www.softperfect.com/products/filerecovery/ seems to a decent recovery program.
It the file was on a network drive, you will have to use the recovery program to try and restore it.
The quicker you do this the better the chances of recovering the file.
As the space is marked available in the drive management table, it will eventually be overwritten.
Regards Brad
Brad Coleman, Electrical Draftsman
testsubject
Brad,
Good call. I burn my recicle bin a couple of times a day so It is usually empty...
Bob Hanrahan
Ace User since 1998
”Boost
