AutoCAD Electrical General
Valued Contributor
rwydesk500
Message 1 of 6 (160 Views)
WDP File Inadvertantly Deleted
160 Views, 5 Replies
06-20-2012 11:49 AM
If the WDP file inadvertantly gets deleted from the project folder, is it possible to regenerate a new one?
Rick Yoerger
AutoCAD Electrical 2014
testsubject
Message 2 of 6 (157 Views)
Re: WDP File Inadvertantly Deleted
06-20-2012 12:43 PM in reply to: rwydesk500
Sorry, Rick.
AFAIK, unless you have a backup, you will have to create it over again from scratch.
Hopefully this will not be too painful for you.
Bob Hanrahan
Ace User since 1998
Valued Contributor
rwydesk500
Message 3 of 6 (154 Views)
06-20-2012 01:09 PM in reply to: testsubject
Yikes! That's a backup more valuable than a .BAK file. :smileywink:
Rick Yoerger
testsubject
Message 4 of 6 (148 Views)
06-20-2012 01:49 PM in reply to: rwydesk500
You're not kidding since there is no simple way of extracting the drawing descriptions to repopulate the drawing properties part of the WDP.
Bob Hanrahan
Ace User since 1998
Icemanau
Message 5 of 6 (143 Views)
06-20-2012 04:21 PM in reply to: rwydesk500
Depending on how the file got deleted, you MAY be able to recover it easily.
Check the recylce bin if it is a local file, and you may be able to recover it from there if just the delete key was pressed.
If it was deleted using SHIFT-DEL, you will need to look for and find a recovery program to recover it.
http://www.softperfect.com/products/filerecovery/ seems to a decent recovery program.
It the file was on a network drive, you will have to use the recovery program to try and restore it.
The quicker you do this the better the chances of recovering the file.
As the space is marked available in the drive management table, it will eventually be overwritten.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
testsubject
Message 6 of 6 (135 Views)
06-20-2012 07:10 PM in reply to: rwydesk500
Brad,
Good call. I burn my recicle bin a couple of times a day so It is usually empty...
Bob Hanrahan
Ace User since 1998
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
