Is there a way to get a list of all of the valid properties used in symbols. The manual lists a lot of them, but it seems to me that looking at some of the provided symbols, there are some undocumented ones (or undocumented ways to use current ones).
I would also like to write some custom routines (maybe to help with previous post), but don't know where to start. I get the impression that there a lot of choices to add routines (LISP, VBA, VLISP, etc.), but anytime I try to use a *.lsp file in WD SA 16.0, it tells me that "load" is unavailable. If I try "appload", it won't load *.lsp files. Since I don't know LISP right now, VB would probably be the easiest (although I am working on picking up LISP right now).
Are the Routines listed in the manual the only ones available? Is there a way to have a routine run at specific program events (like insertion of a component, addition of a wire, etc)?
Scott
