Can I change the sorting in the report?
Instead «S1 S10 S11 S12 ... S2 ...» need «S1 S2 S3 S4 ... S11 S12 ...»?
The reports are not allowed to list all values if they are arranged in order, is enough to indicate the first and last value, for example, «S1 ... S36».
Option «User Post» help me with this?
You can du this MANUALLY bym in the report generator, press Edit Mode and the select the lines to edit, and press Edit.
Of course, you can always create your own litte LISP-program to do this automatically via User Post.
It is a pity that Autodesk does not want to write us this little program.
Doesn't everyone need this?
Users are not capricious and do not find fault with the program.
The design standard requires them to have a certain kind of report. If the report is generated in a different form, then the work has not been completed, you need to redo it.
Maybe proficiency in LISP programming should be mandatory for users?
For example, program developers could add a few LISP programming lessons for users to help, add a ribbon tab with LISP programs, and so on.
Users will be able to write the program they need on LISP - this is a solution.
I proposed this idea in October 2015.
34 votes supported the idea.
The sorting is done alpha-numerically.
I just pad zeroes and have no problem with sorting.
instead of S1, S2, S3 I insert S01, S02, S03...
Now it sorts correctly.
@testsubject wrote:The sorting is done alpha-numerically.
Do you add 0 before a digit manually?
