AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
[VBA] Writing a data from excel to autocad without openning autocad manuelly
3 REPLIES 3
6186 Views, 3 Replies
I have trouble in my task. I am trying to write the data of an excel cell into autocad ( string data ).
The following code is almost right but it doesn't write the text in autocad.
(open autocad and add drawing only)
If anyone has an idea on the problem.
Regards
Nicolas
Code VBA:
Public ThisDrawing As AcadObject
Sub test()
Dim xAP As Excel.Application
Dim xWB As Excel.Workbook
Dim xWS As Excel.Worksheet
Dim Height As Double
Dim P(0 To 2) As Double
Dim TxtObj As AcadText
Dim TxtStr As String
Dim AcadObj As AcadApplication
Dim AcadDoc As AcadDocument
Set xAP = Excel.Application
Set xWB = xAP.Workbooks.Open("C:\Path\Name.xls")
Set xWS = xWB.Worksheets("Sheet1")
MsgBox "Excel says: """ & Cells(1, 1) & """"
On Error Resume Next
Set AcadObj = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then
    Set AcadObj = CreateObject("AutoCAD.Application")
    NombreDessinAutocad = 2
AcadObj.Visible = True
    MsgBox "Step_1"
Set AcadDoc = AcadObj.Application.Documents.Add
MsgBox AcadObj.name & " version " & AcadObj.Version & _
" is running."
Set AcadUtil = AcadDoc.Utility
Set AcadEspaceObj = AcadDoc.ModelSpace
    MsgBox "Step_2"
Height = 10
P(0) = 1: P(1) = 1: P(2) = 0
TxtStr = Cells(1, 1)
    MsgBox TxtStr
Set TxtObj = AcadObj.ModelSpace.AddText(TxtStr, P, Height)    <------doesn't work
Set TxtObj = ThisDrawing.ModelSpace.AddText(TxtStr, P, Height)      <------doesn't work
    MsgBox "End"
End Sub
Tags (1)
3 REPLIES 3
This was a little mystake, her is the solution:
Sub test()
    MsgBox "Step_1"
" is running."
    MsgBox "Step_2"
Height = 10
    MsgBox TxtStr
'Set TxtObj = AcadObj.ModelSpace.AddText(TxtStr, P, Height)    <------doesn't work
'Set TxtObj = ThisDrawing.ModelSpace.AddText(TxtStr, P, Height)      <------doesn't work
Set TxtObj = AcadEspaceObj.AddText(TxtStr, P, Height) <-------- Work !
    MsgBox "End"
End Sub
noveldecor
Hi
Thanks for this post.
I am wanting to do a similar thing.
Can you attached a sample Excel data file along with the Autolisp code which i can load in my autocad file.
Best Wishes
-Arian
lohithna
can you please write a program for inventor application
i  have to write for inventor parts
”Boost
