AutoCAD Electrical Forum
[VBA] Create a folder and a project
3 REPLIES 3
Nicolas.L
1074 Views, 3 Replies
I found how to open autocad and how add drawing by looking on forums and the help section au AtucadElectrical but there is a thing that i can't find:
How to create a folder, a projet and add (new drawing to that folder)
Regards
Nicolas
This is the beginning of the code:
Sub Initialise()
    Dim NewDrawing1 As AcadDocument
    Dim Newdrawing2 As AcadDocument
    On Error Resume Next
        Set AcadObj = GetObject(, "AutoCAD.Application")
        If Err.Number <> 0 Then
            Set AcadObj = CreateObject("AutoCAD.Application")
            NombreDessinAutocad = 2
        End If
        AcadObj.Visible = True
        Set AcadDoc = AcadObj.ActiveDocument
        Set AcadUtil = AcadDoc.Utility
        Set AcadEspaceObj = AcadDoc.ModelSpace
        Set NewDrawing1 = AutoCAD.Application.Documents.Add("")
        Set Newdrawing2 = AutoCAD.Application.Documents.Add("")
        Dim drawing As AcadDocument
        For Each drawing In AutoCAD.Application.Documents
            drawing.Activate
            MsgBox "Drawing " & drawing.Name & " is active."
        Next drawing
    Excel.Application.Visible = True
End Sub
3 REPLIES 3
johnq
in reply to: Nicolas.L
Hi Nicolas
Your question has a lot to it.
While I could show you, it is too long winded to answer here.  I know that is not what you need to know.
I do not sell training so when I suggest you should get some training then it it true.
Now to help with limited 18 months experience:
I could not create a project for scratch.   I needed to open a project from the built in Tutorials in ACE.  Open a drawing from that project.
That project needed to be Active.   It is bold high lighted.
Then I could go through the process of creating a project.
If I had a choice I would have a seperate Letter drive for ACE even if you only had one physical drive.
Also go to www.ecadconsultant .com  There is some good info but I must be thick as some of it I found criptic but eventually I got the message.
Cheers  John QUigley
johnq
in reply to: johnq
Hi Nicolas
I should have tried to find out what VBA was before I tried to help.  I have just made a fool of my self as I think you are using Vault etc.
Forgive me for I know what what i do.
All the best forthe new year.
Cheers  jq
Nicolas.L
in reply to: johnq
Hi John,
First of all thanks to take time on my problem.
I use VBA, maybe it's also call VB, anyway it is a .NET language. I stopped using this language and I goes on a maybe more structural oriented programming language which is C#.
I don't really understood all the things of your answer but I understood that it is not as easy as I thought.
Thanks for your answer,
Have an Happy new year
Nicolas
”Boost
