AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
User attributes in wire numbers
0 REPLIES 0
Message 1 of 1
kghew1
314 Views, 0 Replies
Hi all
I need to use some of the W01USER - W10USER attributes in WD_WNH blocks
The inserted values come out fine in a 'Wire Numbers' export to spreadsheet,
but refuse to appear in a From / To report, even if the WnnUSER field is added to the .wda file as user-defined
I recall some discussion involving Nate Holt et al about a fix which involved replacing a .lsp file with a modified version to get these attributes to work in reports.
Does anyone know if this problem is a bug which still exists, or if a workaround has been devised that doesn't involve modified files - or am I simply missing something ?
Regards
Keith H
0 REPLIES 0
”Boost
