As it is write in the subject when I play my code I have an error that i can't fix !
I have no idea of the source of this error.
If someone can help me to fix it.
Regards
Nicolas
PS: attached to the mail , the code, the error and the source drawing.
Hi Nicolas,
maybe you should post your question in the AutoCAD .NET or VB Customization forum.
Short und simlified: you mix ActiveX and .NET code. That is of course possible. But it seems that you create a exe and from a exe you can access AutoCAD only via ActiveX. Accessing AutoCAD via .NET/ObjectArx, you have to create a dll/arx which runs inside AutoCAD.
- Karl
