I am having a very similar problem when trying to start the terminal strip editor. There is a dialog box asking for saving the drawing, and a message appears that: Data written out to project database tables "WFRM2ALL" and WNETLIST"
I am using ACADe 2011 with all updates
I did import drawings into the project---added using Project Manager.
Pat, how can I update the LINKTERM variable that you spoke of?
I believe this problem has been resolved in ACE2011 Update1, you can patch it from: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15695800&linkID=9240738 and try it again.
Kevin Li
I have already installed this update--several months ago--I have not tried to use the editor for a while.
The TS editor was working previously, but I cannot tell when exactly it stopped.
I have submitted a tech support request.
OK, thanks.
Kevin Li
