AutoCAD Electrical General
Valued Contributor
Message 1 of 9 (1,870 Views)
Undo command disabled?
1870 Views, 8 Replies
12-05-2012 09:24 AM
Why is my UNDO command disabled?
Jim
Member
Message 2 of 9 (1,854 Views)
Re: Undo command disabled?
12-06-2012 04:40 AM in reply to: jdonaldson3
REINSTALL YOUR CAD THATS THE ONLY WAY TO GET YOU UNDO TO WORK RIGHT. I TRIED EVERYTHING AS WELL BUT NOTHING WILL RESTORE IT BUT AN REINSTALL.
rhesusminus
Message 3 of 9 (1,852 Views)
12-06-2012 04:43 AM in reply to: jdonaldson3
Type UNDO at the command-line and select option "One".
Now, the U command undoes one command at a time.
If this doesn't work, type UNDOCTL at the command-line, and tell us what value this is set to...
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Valued Contributor
Message 4 of 9 (1,832 Views)
12-07-2012 06:03 AM in reply to: rhesusminus
That appears to work. But only after I typed UNDO a second time. The first time I typed UNDO and entered 1. Autocrat replied that I needed to enter a number from 1 to 3####. You know a typical Autocrat WTF answer.
Second time around and it worked.
Thanks.
Jim
rhesusminus
Message 5 of 9 (1,830 Views)
12-07-2012 06:13 AM in reply to: jdonaldson3
Hmm..
How about
UNDO
CONTROL
ALL
What does UNDOCTL give you?
THL
Valued Contributor
Message 6 of 9 (1,826 Views)
12-07-2012 09:50 AM in reply to: rhesusminus
UNDOCTL = 48 (read only)
rhesusminus
Message 7 of 9 (1,819 Views)
12-07-2012 04:52 PM in reply to: jdonaldson3
And if you type
UNDO
CONTROL
ALL
what's the value for UNDOCTL then?
THL
Valued Contributor
Message 8 of 9 (1,783 Views)
12-10-2012 06:49 AM in reply to: rhesusminus
UNDOCTL = 53 (read only)
Valued Contributor
Message 9 of 9 (1,780 Views)
12-10-2012 07:06 AM in reply to: jdonaldson3
OK another reason to hate Autodesk. Appearently this has been happening since 2008 Electrical
http://discussion.autodesk.com/forums/thread.jspa?threadID=652307
I am so glad that I get to use software that's had the same bug for over 5 years that dirrectly effects using the software. Thank you  Autodesk.
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
