Heya folks. At my company I am workign on ACADE 2014, and the other projects have been built in 2010. My problem is the default project settings (file locations) is set up for ACADE 2007 or 2010. So, when I go to insert symbols and blocks, it is pointing to the default folder of the project, which doesnt exist on my machine. I have been reestablishing the paths to fit my purposes, but does anyone know of an easier way to do this? Its not difficult to do this way, just time consuming to add/browse 4 additional paths (ok. not really time consuming, just inconvenient). And before anyone accuses me of being lazy, remember: laziness is what helps comes up wiht shrotcuts. 😄
So, in summary, is there an easier way to do this, or am I stuck with the regular way?
Doug
If you edit your wd.env file; fields WD_LIB, WD_PNL, WD_MENU and WD_PMENU, you can use the select Schematic Libraries in the project properties, and press the Default-button to set that setting to whatever you have in the wd.env file.
