Hi all,
I added new attributes to our custom title block and cannot update them with the Title Block Update function.
First of all I am using Autocad Electrical 2009 single user but all my drawings are stored on a network server.
I am not sure what I did wrong, I created a new title block ( from the existing autocad electrical template) with the new attributes and edited the WDT file with the title block setup function, clicked on overwrite and used the pick block to select the block to edit. When the popup opened up I mapped the new attributes to the Line xx that I chose and saved. After this was done I use the swap/update block to update my drawings to the new title block. When I modify the Description file with the new information I want to add to my drawings and use the Title Block update function for all drawings it goes trough the drawings and nothing changes. I can change the other attributes this way but the new ones dont change. The new attributes are for the various revision lines I want to add a date, description of revision and by who it was made...
What am I doing wrong..
