It does look like AcadE strips off any leading spaces. There might be a way
to do this depending on where the value is coming from that you want to
assign to this attribute. You can assign an AutoLisp expression in the .wdt
file to an attribute. Let's say you wanted to assign the First Project
Description line to the attribute name TITLE1 but you wanted to add a space
in front of it. There is an API that returns the Project information,
c:wd_proj_wdp_data. It returns more than you need but the 3rd (nth 2)
element of the return is a list of the project's description lines. The
first description line is held in the 2nd place (nth 1) of that list. So to
get the first description line, the Autolisp expression would be
(nth 1 (nth 2 (c:wd_proj_wdp_data)))
To add a space in front of it, the expression would be
(strcat " " (nth 1 (nth 2 (c:wd_proj_wdp_data))))
So the line in the .wdt file might look like this
TITLE1 = (strcat " " (nth 1 (nth 2 (c:wd_proj_wdp_data))))
If it isn't a project description line you are assigning but something else,
the idea is the same but a different API might be needed to get the
appropriate value.
Pat Murnen
wrote in message news:5153661@discussion.autodesk.com...
One of the attributes in my title blocks in a project of drawing needs to be
moved over one space since it is on one of the title block dividers. I have
tried putting an extra space in the .wdt, .wdp, and in the .wdl files. Also
tried an extra space in the project descriptions. All attempts just ignored
the space in front. I also tried using some wild cards that I thought may
get it to notice the space but nothing has worked so far. Any ideas?
