AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Title block attribute mapping
1 REPLY 1
166 Views, 1 Reply
Is there a way to force the use of a .wdt file when the drawing has a block with a WD_TB attribute already? -- John Pullen TDS Automation A Doerfer Company ---------------------- Please reply to newsgroups.
1 REPLY 1
John, No, the program first searches the block definitions defined in the active drawing for any that include an attribute definition "WD_TB". If found, that's the block insert it goes for and doesn't proceed with a search for a ".wdt" file. If not found, that's when it reverts to using the ".wdt" file method. Nate. "John Pullen" wrote in message news:40a93d2e$1_1@newsprd01... > Is there a way to force the use of a .wdt file when the drawing has a block > with a WD_TB attribute already? > > -- > John Pullen > TDS Automation > A Doerfer Company > ---------------------- > Please reply to newsgroups. > >
”Boost
