Can someone please advise on how to change the Description Lines for Title Block mappings to meaningful text, ie. the prompt text of the attribute rather than Line 1, Line 2, Line 3 etc as I need to cross reference these line number each time I am doing a title block update.
Thanks in advance.
What you are looking for is the default_wdtitle.wdl file.
It is located at
C:\Users\Yourname\AppData\Roaming\Autodesk\AutoCAD Electrical 20yy\R1#.#\enu\Support\User
Replace yourname, 20yy, and R1#.# with your name, year and release.
Here is a copy of mine so you can see the format.
I have some screen grabs on this blog post as well as some info on the file search sequence.
Title Block Update - The Basics
