AutoCAD Electrical General
Valued Contributor
Message 1 of 6 (298 Views)
Text style for wire color/gauge
298 Views, 5 Replies
02-04-2013 10:53 AM
I've been using Electrical 2010 for a little while now, but for the life of me I cannot remember how to change the text syle of the wire color/gauge leader. It comes in on the 'standard' layer, but I want to use 'simplex'. How do I change it? I can't seem to find any information for this particular issue.
Thanks in advance. :smileyhappy:
Julie
Active Contributor
btackes
Message 2 of 6 (286 Views)
Re: Text style for wire color/gauge
02-04-2013 01:43 PM in reply to: junkinjam
"The label text size follows the current AutoCAD DIMTXT setting and the arrow size defaults to the current AutoCAD DIMASZ setting."  Font style is DIMSTLYE
Valued Contributor
Message 3 of 6 (282 Views)
02-04-2013 01:51 PM in reply to: junkinjam
Yes, I did read that. But where would I find the DIMTXT setting? If I enter 'dimtxt' on the command line it only gives me the option of changing the text size, not the font.
Thanks.
Active Contributor
btackes
Message 4 of 6 (278 Views)
02-04-2013 02:01 PM in reply to: junkinjam
Font style is DIMSTYLE then click modify
Message 5 of 6 (277 Views)
02-04-2013 02:03 PM in reply to: junkinjam
Go to the Format menu and select the Dimension Style.
Now select the Text tab and you can change the font, style, size and a few other items. Other tabs allow you to change other settings to do with dimensioning.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Valued Contributor
Message 6 of 6 (250 Views)
02-06-2013 04:46 PM in reply to: Icemanau
Thanks! That was what I needed :smileyhappy:
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
