Hi All,
I am having a strange issue.
If I insert any terminal or connector the wire numbers change.
I have checked the block name and the 3rd character is in fact "0"
i have looked at project setting, drawing settings. Not sure what to try next.
I am using symbol HT0002 and symbol HC01JP
Are you sure your project is not set for wire numbering on a per wire basis? See the attached image which shows a project that is set for wire numbering on a per-wire basis. This setting over-rules the "0" portion of a symbol file name. See the attached example of wire numbers forced to change across terminal blocks that normally do not force a wire number change.
Thank you sir! I am not new to autocad however its been 4 years since the last time I had to use electrical. I should have maybe read over the help file a little better on the set-up screen you referenced. I was at your site today and looked over some of your tutorials. A+
I'm glad I could help.
