Hi Sathya,
You can use X1TERMxx where xx can increment 01, 02, 03 etc. You can have a
matching TERMxx TERMDESCxx attribute which can be used as terminal number
and terminal description.
One way of updating/ changing information on the entire project is to export
the information from the project into an XL sheet use the command Project ->
Export to spreadsheet. Change whatever you need in the xl sheet and import
it back to the project.
Hope this helps
Giri.
wrote in message news:4904427@discussion.autodesk.com...
Hi
I've a problem with terninal strips. i want to add 4 more terminals to my
terminal strip, now i've x1term01, x2term01, x4ter01, and x08tem01. now i
want to add 4 more terminals . how i have to name these terminals? also if i
use swap block
command it displaces the blocks eventhough the insertion point is same..
will u l let me know about this?
I modified the catalog ingo for deveice "hcr1" inone drawing. i want to
update the info for all the relays "cr family" in the project. how can i do
this? can any one help me ?
regards
sathya
