AutoCAD Electrical Forum
Terminal sttrip and catalog update
2 REPLIES 2
186 Views, 2 Replies
Hi
I've a problem with terninal strips. i want to add 4 more terminals to my terminal strip, now i've x1term01, x2term01, x4ter01, and x08tem01. now i want to add 4 more terminals . how i have to name these terminals? also if i use swap block
command it displaces the blocks eventhough the insertion point is same.. will u l let me know about this?
I modified the catalog ingo for deveice "hcr1" inone drawing. i want to update the info for all the relays "cr family" in the project. how can i do this? can any one help me ?
regards
sathya
2 REPLIES 2
Hi Sathya,
You can use X1TERMxx where xx can increment 01, 02, 03 etc. You can have a
matching TERMxx TERMDESCxx attribute which can be used as terminal number
and terminal description.
One way of updating/ changing information on the entire project is to export
the information from the project into an XL sheet use the command Project ->
Export to spreadsheet. Change whatever you need in the xl sheet and import
it back to the project.
Hope this helps
Giri.
wrote in message news:4904427@discussion.autodesk.com...
Hi
use swap block
regards
sathya
hi giri
thanks a heap but i could not get the info regarding the terminals for terminal strip..
can u please explain in detail.....how can i update the catalog info for all the components at a time?
and i want to get a report on pins(NO NC contacts) used for each and every component(eg relay) for entire project? how can do this?
pl help me out..regards
sathya
”Boost
