You can set the attributes to visible if you want to see them. The best way to make visible and change the text size is with regular AutoCAD Properties. If you want this to be visible by default, edit the terminal footprint files and set the attirbutes to visible and to the size you desire.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
