At a very basic level, don't use the terminal blocks on the far right side
on the menu, those cause the wire number to change.
"tomw47" wrote in message
news:1275601.1083677905062.JavaMail.jive@jiveforum2.autodesk.com...
> How do I keep wire numbers on each side of a terminal to remain the same
after inserting a terminal? Typically, a wire being connected to a terminal
strip carries the same wire number as the terminal block.
> Thanks
