Hi
When we build panels, we would usually identify the terminals by the wire number, rather than a simple number sequence. Is there a way to "sort" the terminals in wire number order. I can sort them in the terminal editor but this can take quite some time with hundreds of terminals in a panel. I tried exporting to Excel but couldn't get that to work.
Regards
John
Solved by JohnSmith5014. Go to Solution.
I usually go into terminal editor and open up a terinal strip. Once I have the ternimal strip open I double click the column for terminal numbers and it sorts the ther terminals for me. I sometimes have to do further adjustments because of how we like to order and seperate the terminals.
Scott
Hi Scott
Gosh - that was easy - I feel such an idiot now. I spent ages moving terminals - Thanks for your help
Regards
John
