When I enter the terminal strip editor I have to manually change the properties of each terminal to give it the correct level and the correct number of wires per connection. I thought the L0nPINR and L0nPINL attributes automatically did this in the block; am I correct? (I could understand if it did the number of wires on the left and the right but not the level!!) If this is not correct do I need to add further attributes or do I need to change something elsewhere so that when the terminals are chosen, they automatically have the correct levels and wires per connection? I am using ACADE 2010
