AutoCAD Electrical Forum
Terminal Editor Corruption
10 REPLIES 10
Message 1 of 11
dbrblg
1187 Views, 10 Replies
I'm having some issues with the terminal block editor as you'll be able to see from the attached image....
Firstly, why are there yellow highlights?  I cannot find anything in the documentation.
The second, and possibily more relevant thing, is why there are multiple wire connections when there shouldn't be.
If you take the first terminal for instance.  In the yellow highlighted area there is device Z1103.  The terminal this device is attached to is in another terminal rail (x3 in this case)!!  The same is actually true of U1171 further down the list along with a lot of others.  Why are terminals from another terminal rail in this one?
Another thing is that this particular terminal is in the database as a single level terminal so why are two L1's available per terminal?
In my mind it is pointing to some kind of corruption but I've tried rebuilding the project database, updating the project but nothing seems to be clearing this issue.
Does anyone know how to solve this issue?
10 REPLIES 10
Message 2 of 11
Icemanau
in reply to: dbrblg
I don't know about the Yellow Highlights but they could just be for contrast between the lines.
The terminal information for the database entry could be allowing TWO wires per connection point which is why you have what looks like a second level. A dual level terminal (or triple level) shows as a slightly different setup.
To see what terminal information is tied to the catalog entry, open the TSE and select the terminal strip. Now right click on one of the terminals. Select Block Properties from the popup and this will list the information for that terminal type. ACADE does include a tool to edit the settings for the terminal information. you will have to do a quick search for it. I sue the drop down menus and turn the ribbon off so I'm not sure where on the ribbon it would be. In the drop down menu it was located under Components->Terminals as Terminal Properties Database Editor
See the TSE image I've attached. It shows some single level terminals and some triple level terminals.
As for the terminals from another strip being included in this strip, all I can suggest is to actually edit the terminals in the schematic, check what strip they are assigned to and then save and close the project.
Now find the <PROJECT_NAME>.mdb file and delete it. This file is the actual project database and can become corrupt quite easily. NOTE that for this step you may be required to close ACADE itself.
Finally, open the project again and ACADE will rebuild the project database from the dwgs.
Regards Brad
Icemanau (NNTP handle: Brad Coleman
AutoCAD Electrical User and IT Hardware Support
Message 3 of 11
dbrblg
in reply to: dbrblg
Hi, thanks for your reply.
I tried deleting the project DB but I still get the same results.  I have seen something about refreshing the TERMLINK attribute but cannot find any command to do this.  Not sure of its relevance so maybe something to try if I could find out how to do it.
Shame abouy Autodesks lack of documentation regarding the extra yellow highlighting...
Message 4 of 11
s.wile
in reply to: dbrblg
The yellow rows typically mean you have too many wires per side. According to my default Terminal Properties database, an AB 1492-J can accept two connections per side. That is why there are two rows. In my case I have three on one side and four on the other. So the terminal strip editor is highlighting the bottom two rows as an issue.
I don’t know why yours are showing as yellow.
As for the extra connections... Try surfing on these terminals and see if anything odd is associated to this strip. Maybe also verify that you can edit/see the Terminals Properties tables using the Terminal Properties Database Editor.
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
Message 5 of 11
dbrblg
in reply to: s.wile
To all intents the terminals are ok.  You can surf on them and they have the correct properties (that I can make out from the help files!!)  I have tried swapping to another catalog number but the same problems exist.
Very strange this.
Something I've also noticed, when I place a terminal, I am unable to chose lower or upper from the properties/associations box.  I t defaults to upper when I edit component and flicks back to upper when I click on lower.....
Message 6 of 11
dbrblg
in reply to: dbrblg
Well, I have made some progress in identifying the problem.  What remains is how to solve it.
As you can see from the "Terminal Before" image, I have some yellow highlights indicating I have extra connections to the terminals.  The "Terminals After" image shows the problem goes away when I remove some wires in the schematic. The "Schematic" image shows what I did - basically I removed some wires from the terminals with the same number and the problem goes away.
I can sort of see why the termial strip editor is getting confused - there are a number of extra connections to a terminal of the same number but I would have thought ACADE would have been intelligent enough to consider this kind of problem.  Adding jumper bars between the terminals has no effect.
This does sound like this is a bug to me as I cannot see any other way of creating a terminal rail without connecting the wires to the remaining terminals and adding a jumper.
Does anyone else have this problem?  If this is not a problem, perhaps Autodesk would advise how the software is intended to be used to create terminals in this way?
Message 7 of 11
Icemanau
in reply to: dbrblg
Have you set your wire sequence?
I know that ACADE has some trouble defining the wire sequence when just using the connection dots.
It is quite possible that ACADE is automatically taking some of the wires Direct to Terminal when they need to be looped instead.
Regards Brad
Message 8 of 11
dbrblg
in reply to: dbrblg
Hi Brad,
Not sure what you mean by wire sequence but I have no overrides on Tag/Wire Order Number Order, Solid Wire Cross  and Dot Wire Tee.
Out of interest, I changed these settings a few times yet I still get the same results, in my case at least.
Am I the only one who draws like this?  How do others achieve the same thing? Is it something I am doing wrong Smiley Frustrated
Message 9 of 11
Icemanau
in reply to: dbrblg
The wire sequence tells ACADE how the wire is going to be run physically. We can show a switch next to a CB and then a contact and finally a terminal, with them all having a common connection.
When wired, we would possibly go from the CB to the contact, then to the terminal before ending at the switch. ACAD would see the sequence as the Switch, CB, contact and then the terminal. ACADE could also decide to wire everything back to the terminal (Direct to Terminal) or some mix of the two. This is possibly what ACADE is doing in your case.
I'm not sure where the Wire Sequence tool is on the ribbon but it should be under the Wires tool. This tool will provide a list of how the wires are connected when you select a wire. It will also show any direct to terminal wires. If there are any Direct to Terminal wires, clear the sequence and then set the sequence to what you need.
Hopefully this will clear your problem with the terminal on that wire. To clear all of them, you would need to do this on ALL the wires connected to the problem terminals.
Regards Brad
Message 10 of 11
dbrblg
in reply to: Icemanau
I had a play around with the wire sequence and no matter which combination I tried, I would not get any different results.
I did some more research and found this article which does kind of indicate there is some confusion on ACADEs part when using dots instead of angles as it does not know where the wire joins are located on the wire.
I did some exprimentation with a cutdown version of the diagram - one using dots and the other angles to see what happens within ACADE.  The result, well different depending on whether you use a dot or an angle.  The angle surprisingly still shows an error.....Smiley Frustrated
Message 11 of 11
Icemanau
in reply to: dbrblg
OK, I can see another problem with whats happening...
The terminals seem to be set to ONE (1) wire per connection point. ACADE is automatically adding an extra terminal to the list due to the fact that the terminal settings only have 1 wire per connection.
You need to use a terminal that has TWO (2) wires per connection point.
See the attached clip showing the Terminal Databse Editor Window.
I've highlighted the column showing the Wires per Connection
The entire problem is caused by both the wire sequencing and number of wires per connection point.
It may also be compounded by not setting the Internal/External connections of the terminal. This tells ACADE which side of the terminal to actually place the wire in the TSE.
The second attachment shows the Internal/External settings on some terminals and how they effect the TSE. The Highlighted entries on the TSE show the INTERNAL connection points to those terminals.
Regards Brad
”Boost
