Is it possible to have sheet numbers as well as wire numbers against the terminals when generating the terminal rails through the 'Terminal Footprint Editor' command?
Please advise.
Thanks in advance.
There is no option for %S to be added to the format (see attached image with list of available replaceable parameters). Having %S would be helpful if your wire numbers are not sheet or line reference based. If your components are sheet or line reference based you could select the option, Wire Number Tag. I assume your ultimate goal is to be able to see where the wire is coming from, so the tag of the device would reveal that, if it is sheet or line reference based. This is why I avoid sequential tagging when possible.
