Show only
Search instead for
Is there a way I can change how my bill of materials lays out. Right now I have 20 terminals. When I select "Display in Tallied Purchase List format" I get 20 item numbers that go onto my bill of materials. Is there a way were I can have it list one item number instead of 20 of them. Here is what I'm getting.
You have to check the button "Tallied Format". If you check by "Tag Name", you'll get a line for each terminal. ACE doesn't know that each terminal is the same thing because it adds the wire number to the tag name and therefore see each one as a different device.
I checked the tallied format. I get this for every item that is on my bill of material more than once. Fuses, Selector switch's, drives etc. It's not just the terminals.
