have a little problem.
I am marking components in my drawings with TAG format =% A% F% S% N (section-family code-sheet-Colum)
The problem is that I need to have each section 01 or 02 and so on, can’t have just 1 or 2
So the relay is in section 01 page 02 line 5 receives the name 01K025
But it is required to have the name 1K025
Do you know of a way to remove the zero in front without going into each item deled?
