Peter, the drawing list doesn't support this the same way as the BOM report.
You could do it with a User Post. I am trying to think if there might be a
way to do this using the Title Block setup file. Let me put some thought
into this and if I come up with anything I will post a reply.
If you want to try a User Post let me know if you need any help. I can give
you an example but for this report many of the fields and the order depend
on the specific title block and setup used, so you would need to modify it
for your use.
Pat Murnen
wrote in message news:5642780@discussion.autodesk.com...
[Quote]AcadE supports putting a number of
fields in one Description [Unquote]
Interesting Pat, but is this also possible with the Drawing List Report?
There this option is unavailable. What i want to do is to put 2 of my
drawing titles attributes in the same cell on my dwg.
Peter
