One of my guys has AutoCAD Elec. 2014 and has been having this problem with the pgp file.
There is nothing wrong with the file. He's reinstalled Elec. 3 times with the same problem.
I loaded my pgp and get the same problem.
The file is there, the path is correct.
I've been using AutoCAD a long time and have never had a problem with the pgp file.
Anyone have clue what could be causing this?
Thanks, Kim
Thanks for responding,
Yes, it is the right pgp. Like I said I loaded my pgp and it has the same problem, so it isn't the pgp. It's the application, I just don't know what's causing it.
I've been using AutoCAD since Rel10 and have never had a problem with the pgp file.
Kim
Seems to me like it's AcadE. Try to delete/rename the ACAD.PGP-file and run reinit.
It gives the same error message even without a ACAD.PGP-file 🙂
Everything seems to work anywho... I'm running AcadE 2014 by the way...
Hi Kim,
Did you ever find the solution for the Syntac error for the acad.pgp file? I got this error message below and it's very similar to yours.
Syntax error in acad.pgp file on line 111 in field 1
Would love to hear from you if you guys found the solution for the problem. Thanks in advance.
Connie
Hello Trond,
Please see attachment. Thanks for your help.
Connie
Just tried now, with a fresh install of AutoCAD Electrical 2018, no migration.
Running the reinit command to reinitialize the pgp-file gives an error message.
@PatMurnen_Adsk Can you check with "someone" why we get this error?
I get the same error as you. It does seem like it is the REINIT command rather than the PGP file. I am reaching out to people on the AutoCAD Electrical support team to see if this is a known issue and if there is a fix. As soon as I hear anything I will post here.
Pat Murnen
I did hear back from support on this and they were able to reproduce it so it is now logged. It doesn't appear to be the acad.pgp file format but something going on with the reinit command.
Sorry for this inconvenience,
Pat Murnen
This issue also occurs in 2018 Civil 3D when you add a new command alias and it executes the reinit command. I get 19 syntax errors reported. It only happens with reinit and not when you load up C3D.
I'm seeing this as well, on 2021. I used to be running ACE 2018, recently installed the new version.
I wonder if there's some registry involvement or something?
I have installed a trial copy of ACE 2021 on a laptop that had never seen an ACAD installation problem before, and the issue with the error reported by REINIT is not there, even if I delete the ACAD.PGP.
Maybe if someone at Autodesk could give us a hint how they fixed it, it would help me track it down. I reported a problem with this on the ACAD.PGP forum before I found this thread, and no one could reproduce it.
Now I'm thinking it has to be a cached or shared PGP file somewhere that wasn't removed when I upgraded, but so far my searches have come up empty. It's not a error that causes any issues, just annoying that it can send you down a rabbit-hole when there's nothing actually wrong with the ACAD.PGP, and you see the same error if the system doesn't see ACAD.PGP on the search path.
... I meant to say reported to the general ACAD forum... 😉
Incidentally I just checked with a couple other users... both have ACE 2018 installed, one system has this issue & the other does not. Both customized identically at installation by our IT dept... Weird.
Looks like I found the culprit... at least on my own installation that is...
%appdata%\Autodesk\AutoCAD Electrical 2021\R24.0\enu\Support contains a file acadSynonymsGlobalDB.pgp that once removed, eliminates my "Syntax error in ACAD.PGP on line 3, column 1" erroneous error.
I experimented with editing this, and discovered the problem is apparently the second line in the file is TOO LONG. Change the top 3 lines in the file to read like the text copied below, and the "error" will go away.:
; This .pgp file contains a list of command synonyms. You can also add your own synonyms.
; Each synonym can point to only one command and should not conflict with any command
; alias defined in the product PGP file.
The REINIT command in ACADE 2022 is still affected.
It spits out an error "SYNTAX ERROR in acad.pgp file on line 3 field 1" as above - revised every discoverable version of the file acadSynonymsGlobalDB.pgp and it went away. Really sad that we have to fix AutoDESK's code from at least 7 years ago to present.
