AutoCAD Electrical Forum
Symbol Builder Attribute Editor pallet
13 REPLIES 13
Message 1 of 14
rochestersignal
2326 Views, 13 Replies
How do you turn on the Symbol Builder Attribute Editor pallet?  I turned this off by mistake.
13 REPLIES 13
Message 2 of 14
There is a button to turn it on, placed on the Symbol Builder tab in the ribbon. This ribbon is only available when the symbol builder/block editor is active.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 14
I have four panels in my ribbon.  Done, Symbol Audit Palette Visability Toggle, Symbol Builder Help and Close Block Edtior. I don't see a button, can you help a little more?
Message 4 of 14
The Palette Visibility Toggle button on the Symbol Builder ribbon tab turns the palette off and on. I've attached an image showing the button.
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Message 5 of 14
Thx for all the help!
Message 6 of 14
in reply to: rochestersignal
I have this same issue, but I do not have the Symbol Builder ribbon tab.
AutoCAD 2017
See attached screen snip.
Message 7 of 14
PatMurnen_Adsk
The Symbol Builder ribbon tab only appears when you run the Symbol Build command; Schematic tab > Other Tools panel > Symbol Builder. Are you in the Symbol Builder command and you still don't see the ribbon?
Pat Murnen
Pat Murnen
Message 8 of 14
in reply to: PatMurnen_Adsk
Figured it out.
Message 9 of 14
I just have the regular menus, nothing related to Electrical.
LAYERS, ANNOTATION, DRAW, MODIFY, BLOCK, PROPERTIES, ETC.
How do i get the other menus?  The goal is to get to the Symbol Builder.
Thx,
Craig
Message 10 of 14
PatMurnen_Adsk
Hi Craig,
Assuming you are running AutoCAD Electrical and not just plain AutoCAD, the first thing to try is changing to the default AutoCAD Electrical workspace. This should bring up the ribbon with the electrical tabs along with some general AutoCAD tabs.
Look in the lower right corner and select what I am showing in this image to change to this workspace.
Symbol Builder is on the Schematic tab > Other Tools panel.
Pat Murnen
Pat Murnen
Message 11 of 14
Thanks, Pat!
Message 12 of 14
PatMurnen_Adsk
you're welcome 🙂
Pat Murnen
Message 13 of 14
i have that same problem but in my case i click on the palette visibility toggle but nothing happens, so i dont know what to do. and i am in the symbol builder editor.
Message 14 of 14
rhesusminus
There are three separate problems in this thread. Which one is the same problems as you have?
Did you try to change the workspace?
Have you tried reset to default? https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Trond Hasse Lie
Ctrl Alt El
”Boost
