Hi Martin,
Probably the quickest way to flip these terminals is just to rename the
block. You can use the regular AutoCAD "Rename" > "Block" command. Change
all HT0002 blocks to HT1002 and all VT0002 to VT1002. The key is the 3rd
char of the block name. If it is a "0" then AcadE will run the wire number
straight through the symbol. If you flip it to "1", then it will force a
wire number change through it.
An AcadE terminal symbol that changes the wire number through it is exactly
the same as the terminal the maintains a wire number through it except for
the block name's 3rd char.
Nate.
wrote in message news:5421149@discussion.autodesk.com...
I am an AE newbie, familiar with RSWire.
After doing a Promis-E conversion of a project, all my terminal in AE are
now "wire number same across terminal" rather than the previous "wire number
changes across terminal".
This has messed up all the wire numbering as well as leaving all the
terminals of the wrong type.
Attempting a Swap block for terminals, and making the new block a "wire
number changes across terminal" type, does not in fact change the terminal
to the correct type. The resulting block is HT1002 rather than the VT1002
that I picked.
How can I overcome this problem? Alternatively which attribute sets the
wire number change (or not ) and can I do a project-wide attribute change?
MR
