I suggest editing the WD.ENV file found in your AeData folder, one level above User. There is a line in the file that looks like this: *WD_INSCOMPDLG,x:/some path/,to override starting path for INS SCHEM COMP browse button
The asterisk at the beginning prevents the line from being executed. Remove the asterisk and edit the x:/some path/ to match the absolute path to your custom blocks. ACE will go there each time you select Browse from the Insert Schematic Component dialog box.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
