Sorry, there is no support at this time for using the sub-assembly BOM
assignment concept across tables in the catalog lookup database. The only
way I can think of to do what you want (other than using the "multiple BOM"
idea you mention) is to copy the key items you need from the TRMS table over
to your CB table. Then you'd establish the sub-assembly links for the part
number picks you want, all within the CB table.
Nate.
wrote in message news:5014881@discussion.autodesk.com...
Is there a way to cross ref. between tables? My company uses the Phoenix
TCP CB with the TB base. The breaker is in the CB table and the base is in
the TRMS table. I know I can use the multiple catalog but I want to cross
ref. between tables without doing that. Can anyone help?
