AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Stretching or editing the length
6 REPLIES 6
CAD-ICE
1337 Views, 6 Replies
Hi all!
Is there a tool that allows stretching of a Dinrail after it´s inserted in a panel layout?
Thank´s in advance.
Gary
6 REPLIES 6
lionSG
in reply to: CAD-ICE
Sometime I use the stretch connector, under schematic tab > edit components panel to extend or stretch the DIN rail.
Dunno if it works for you.
OP21
Via the Ribbon ->/ Schematic / Edit Components / (under the scoot drop down) / Strech PLC Module
or
Via the menu->/ Components / Component Miscellaneous / Stretch PLC Module
Hope this helps!
Omar
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
CAD-ICE
in reply to: lionSG
Nope it´s not working on ACADE2013...Smiley Sad
Tank´s anyway. Gary
s.wile
Try it again. This is 2013 and it works for me.
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
testsubject
in reply to: s.wile
That does stretch the length but if you want it to look correct (i.e., appropriate slots, holes, etc) the you will have to redraw it using Insert DInrail from the menu. This block is parametrically built each time it is used.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
dougmcalexander
The stretch PLC command was named stretch block in earlier versions. It still performs the same though. It explodes a block, allows you to use AutoCAD's stretch command, and then recompiles the block. It will work with any block, not just a PLC. I actually used CUI to rename the command to stretch block again. But Bob is right. If you are going to stretch a DIN rail very far it is best to reinsert it. Stretch doesn't adjust the slots. Hint: use it to stretch wire duct as well.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
