Hi all!
Is there a tool that allows stretching of a Dinrail after it´s inserted in a panel layout?
Thank´s in advance.
Gary
Sometime I use the stretch connector, under schematic tab > edit components panel to extend or stretch the DIN rail.
Dunno if it works for you.
Via the Ribbon ->/ Schematic / Edit Components / (under the scoot drop down) / Strech PLC Module
or
Via the menu->/ Components / Component Miscellaneous / Stretch PLC Module
Hope this helps!
Omar
That does stretch the length but if you want it to look correct (i.e., appropriate slots, holes, etc) the you will have to redraw it using Insert DInrail from the menu. This block is parametrically built each time it is used.
