AutoCAD Electrical General
Member
Va7YYupZ
Message 1 of 7 (338 Views)
Strange items near connector showing up
338 Views, 6 Replies
03-05-2013 06:27 AM
These pin numbers and small contact symbols show up to the right of my connector after I insert a copied connector.  They aren't attributes of the connector but they are grouped.  I usually just erase them but what is their purpose and why are they showing up?
thanks
algerj
Message 2 of 7 (320 Views)
Re: Strange items near connector showing up
03-05-2013 07:12 AM in reply to: Va7YYupZ
HI Va7YYupZ,
Its probably part of the Custom Component you "Copied".
You can edit the component using the Symbol builder, and remove the contact set and pins from there.
Then Re-save the component.
... Or did you just Ctrl c and ctrl v... in which case you probably grabbed the contact set by accidentally using the Crossing window selection method (the green dashed box).
Either way, I hope this helps,
James Alger
SolidCAD
Member
Va7YYupZ
Message 3 of 7 (318 Views)
03-05-2013 07:18 AM in reply to: algerj
Thank you, its not a custom connector though.  I just did a quick test.  I used AECONNECTOR and placed a connector no problem, then copied the connector and the items showed up.  It's not a show-stopper, just strange. see pic
algerj
Message 4 of 7 (308 Views)
03-05-2013 07:34 AM in reply to: Va7YYupZ
Hmmmm...
Does the issue occur on other projects?
or is it limited to one project?
If its is only on a specific drawing then try running an aduit (Big "A" > Drawing ultities> Aduit).
Can you send (post) a drawing with a working and a non working connector?
Let me know,
James Alger
SolidCAD
bpasqualini
Message 5 of 7 (297 Views)
03-05-2013 08:22 AM in reply to: algerj
You can do this when you update the xref for the folder.
It's a kind of XREF I don't understand (try to add nex pins and you will see that there is no change).
Use the AEHIDEXREF command to hide these texts.
Regards.
Member
Va7YYupZ
Message 6 of 7 (294 Views)
03-05-2013 08:45 AM in reply to: bpasqualini
OK I used AEHIDEXREF and clicked on the connector (not the items) and they disappeared.
Thank you
algerj
Message 7 of 7 (289 Views)
03-05-2013 09:08 AM in reply to: Va7YYupZ
Hi Va7YYupZ,
Also so you don't have to keep hiding it...
Check to make sure you don't have the "Component Override" toggle on, in the Edit Component dialog box.
James Alger
SolidCAD
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
