AutoCAD Electrical Forum
Startup Suite
4 REPLIES 4
dlshood
352 Views, 4 Replies
Startup Suite
For some unknown reason, my lisp routines that are added to the AutoCAD Startup Suite do not load each and every time with AutoCAD. Does anyone have any idea what is happening? I have noticed that the Acad.lsp also may not be loading when I start my session.
Dave Shood
4 REPLIES 4
in reply to: dlshood
This may help or not. This happened to me when the Admin. personel t my company changed server directories. Cad didn't give me an error or anything. It just wouldn't load. If your startup contents are on the server I would recommend placing them locally. Hope this helps! If not, sorry... "dlshood" wrote in message news:26325057.1079455408666.JavaMail.jive@jiveforum2.autodesk.com... > For some unknown reason, my lisp routines that are added to the AutoCAD Startup Suite do not load each and every time with AutoCAD. Does anyone have any idea what is happening? I have noticed that the Acad.lsp also may not be loading when I start my session. > Thanks, > Dave Shood
MartinLee
You can also modify the ACAD.MNL file and add load lisp commands. Just be sure that you have a backup of this file so that later versions of ACADE won't destroy your modification. Here is a sample from my MNL file.
(defun-q ELEC_STARTUP ( )
(load "burst")
(load "ctxt")
(load "cirtxt")
(load "mckee3w")
(setq S::STARTUP (append S::STARTUP ELEC_STARTUP))
MartinLee
I forgot one thing: This code is added to the end of the MNL file, just before the (princ) statement.
Martin
dlshood
Thanks for your reply... I am aware of adding lisps into the acad.mnl but I really liked the new Start-up Suite feature offered in AutoCAD.
Dave
”Boost
