Anybody available to help me out in this problem?
I am using the Spreadsheet to PLC I/O Utility Tool to generate multiple type of card schematics automatically, I have two limiting in this tool:
1. I can not set up individual distance between devices or terminals, this is something simetric and it is not helping me too much. I have some devices as Barriers and Surge protectors that they are for a single and double chanel and require 4 or more connection pins. I need to ajust the distance between terminals and devices separately.
2. Card module work perfect with the input lines, devices and terminals on line, but when I require and extra terminals in outside lines of the card module, doesn't work. Seen to me this tool was built for a specifics type of PLC as Modicon.Modicon is no the only PLC that we have in the industry.
3. Some cards have some pins on the middle of the channels, I can not customize this configuration on the spreadsheet, because I got mess all terminals and devices when I generate the drawing. The terminals and devices got out from the channel line, this is not good. the spreadsheet must keep your function as a row, because a row in the spreadsheet is a line on the AutoCAD drawing.
4. I know that I can pull many type of cards that I want, using NEW_DWG on the Code column, this give the opportunity to choose new settings for the new drawing, but the spreadsheet must carry a tool of command that call automatically the settings for a new drawing.
I will appreciate somebody can help me to solve that problems , maybe somebody have an idea how we can fix the wdio files on the script, or maybe this is a future improve from AutoCAD staff.
Thanks a lot!
Ricardo Traslavina
I would recommend looking at the PLC Database File Editor.
Hint: You may also insert a saved circuit such as an 3-wire analog device by Placing an asterisk (*) in front of a device block name (DnBLK) to trigger an Insert Circuit instead of an Insert Component. Adding the "*" lets the AutoCAD Spreadsheet Utility know NOT to Block the circuit.
If in need of A-B PLC's this site may be helpful:
See if this link will work for you:
http://web.archive.org/web/20100627200844/http://nateholt.wordpress.com/
if it will, scroll down to the 2/11/2010 entry---
Thank you very much!
I would like to introduce myself and have the oppoertunity to talk with you. This is my e-mail: traslavina.ricardo@gmail.com or rtraslavina@enerflex.com
Thanks!
Good Morning!
I will need a litter help!
1. I am building multiple drawing from Excel spreadsheet to PLC I/O Utility tool, but when I try to break my module with the word "BREAK" on the excell spreadsheet doesn't work, any suggestions?
2. Another problem that I have to solve is the spacing between the devices, This is a simetric distance set up for all of them. Anyway that I can control the distance between devices separatelly?
3. I would like to learn programing with AutoList, Any suggestion or course that I can take from Autodesk AutoCAD or other person?
4. Some modules are coming with the controller, digital inputs and Outputs; and Analog inputs and Outputs. I want to customize a module that it can break in 3 or 4 parts, and be available to change from input to output location in the drawing.
5. I am very interested to customize my wdio.lsp files. I have been working hard to get all things done in my company. We bought 20 AutoCAD Electrical lisences, everything goes very good, but I need help, please if somebody is available to teach and explain me AutoLIST programing, let me know.
I work for Enerflex in Calgary, AB, Canada. Thanks!
