AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Source / destination arrow - attribute WIRECOLOR
3 REPLIES 3
Wheelie22
370 Views, 3 Replies
The attribute WIRECOLOR is not available with the command Edit Component.
How can we use it with AcadE ? and not just attedit.
3 REPLIES 3
testsubject
in reply to: Wheelie22
The color of the wire comes from the layer it is on, not the components. If you want to change the color, use the "Create/Edit Wire Type" command to create the layer and "Change/Convert Wire Type" command to change it.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Wheelie22
No..
If you double click on a arrow you get all the attributes in the Enhaned Attribute Editor, and there is a WIRECOLOR attribute there !
testsubject
I get what you are saying now. Funny thing; I checkedalf a dozen source symbols on my computer (Runnning ACE 2013) and none of them have the WIRECOLOR attribute in them...
Not sure what to tell you. Are you using stock symbols or ones that were created by someone else? What library are you using?
I should state that you should not be changing the attribute with the ACAD Advanced Att Editor. You should be using the ACE's Edit Component instead. If you do it the other way, the project database does not get updated.
Bob Hanrahan
Ace User since 1998
”Boost
