Two possible solutions: 1) use the "Change to Multiple Line" toolbar button
under the Cross-reference toolbar flyout, or 2) if this is a "hot" or
"common" bus that goes from drawing to drawing, try to "daisy-chain" your
source/destination arrows (use source at bottom of wire, destination at top
of same wire in next column or next dwg, source at bottom of that wire, dest
at top of same wire in next column... - use can use the same SIGCODE value
for all of these).
wrote in message news:4911549@discussion.autodesk.com...
Hi
I'm having problem with signal codes..i inserted source signal "HA1S1" and
I have so many numbers of wires to be shown connected. I need multiple lines
for "xref" field. can anybody guide me to get this result...
thanks in advance and regards
sathya
