AutoCAD Electrical General
Active Contributor
Message 1 of 4 (229 Views)
Signal Source and Destination Arrows With PLC Spreadsheet I/O Utility
229 Views, 3 Replies
10-09-2012 11:04 AM
When using the Spreadsheet to PLC I/O Utility, I am unsuccessfully attempting to place source and destination arrows.  I am attempoting to place a source arrow and a destination arrow on the same line.  I can do this manually on the drawing with no problem.  However, when IU attempt to place a source and destination arrow on the same address line, using the spreadsheet, either the source or the destination wire connection drops out.
What can I do to add souce and destination arrows via the PLC spreadsheet
Message 2 of 4 (222 Views)
Re: Signal Source and Destination Arrows With PLC Spreadsheet I/O Utility
10-09-2012 12:39 PM in reply to: Outbound
The drawing you sent out was blank.
Could you resend it so I can take a look at it?
Bob Hanrahan
Ace User since 1998
Valued Contributor
Message 3 of 4 (218 Views)
10-09-2012 01:40 PM in reply to: testsubject
Try these in the DxBLK field:
"HA1D3" - Destination arrow for input cards
"HA1S1" - Source arrow for output cards
You may also add the signal code in DxTAG fields to save time. Be sure to use a unique signal code for each arrow.
Don't forget to try RackLayout.com when creating the Excel sheet.
Active Contributor
Message 4 of 4 (207 Views)
10-10-2012 06:18 AM in reply to: testsubject
Sorry...I failed to attach the sample file properly.
Hopefully, it willbe attached, here.
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
