Is there a way to totally delete a to/from signal reference in Autocad Electrical 2013? You can delete on the drawing but it still shows up in the reference list.
@christina.mccaffery wrote:Is there a way to totally delete a to/from signal reference in Autocad Electrical 2013? You can delete on the drawing but it still shows up in the reference list.
It only stays in the "Recent" list doesn't it? I don't see it in the "Drawing" or "Project" lists. I think this is by design. Say you put in everything for a source signal and picked the wrong wire. Delete the errant one and add a new source and all your stuff is still there in the "Recent" codes list.
And this is presuming you are removing the signal using the proper ACADE command.
