Here is a modified "user post" utility (wirefrm2.lsp and wirefrm2.dcl) that
hopefully will insert "N.O." or "N.C." suffix on to contact tags in the wire
from/to report. If you want to try this, follow these steps:
1. Get into "c:\program files\autodesk\acade 2007\support\" folder
2. Back up files wirefrm2.lsp and wirefrm2.dcl
3. Unzip attached file and overwrite existing file names
Now, when you run a Schematic Wire From/To report, select the "User Post"
button on the right-hand side of the report dialog display. A subdialo
appears with 5 options. Pick the last option. The report will redisplay. If
you have the CMP1 and CMP2 fields displayed in the report, they should now
have "[N.O.]" or "[N.C.]" suffixes if the components are "contacts".
Nate.
"Nate Holt (Autodesk)" wrote in message
news:5246219@discussion.autodesk.com...
Do you want to have this NO or NC show up in the "Wire From/To" report? It
cannot be done directly but can be done by altering the optional "User Post"
AutoLisp utility that goes with this type of report. Let me know...
thanks,
Nate.
wrote in message news:5246009@discussion.autodesk.com...
There is an attribute on NO or NC symbols called CONTACT.
Is there a way to have the value of this attribute (NC or NO) show up in the
Schematic Wiring Report.
I have reviewed the list of replaceable parameters in the Help file and did
not see one that would accomplish this. If this can't be done, is there
another way to read this attribute value.
