Is it possible to include other files than dwg into the sheetmanager ? It would be great if you could have also pdf and xls files.
Solved by Nata_ly. Go to Solution.
Hi!
I've just added pdf file to Project manager (you mean Project manager, right?). But I couldn't see much advantage of this action.
No i mean Sheet Set Manager, it would be great to have the same pages and in the same order as the paper drawings in the folder/binder.
Just make a PDF file, then open <projectname>.wdp in Notepad and tape PDF filename manually on the last line. And re-open the project in ACE.
