AutoCAD Electrical Forum
Searching BLOCK table for attibute "WD_TB". . .
2 REPLIES 2
shanna_zhou
466 Views, 2 Replies
Hi All,
I have a problem when I do batch plot drawings. The plotting stopped on the third drawing and show me message: Searching BLOCK table for attibute "WD_TB". . .
Any idea?
Shanna
2 REPLIES 2
lionSG
in reply to: shanna_zhou
Did you try using the "Publish To DWF" method instead?
After you select the drawings to print, Select from the Publish to: drop down list and select "PDF" type.
Click the "publish options" button if required to change to like multi-sheet file...
Normally I used this way to print the whole project in pdf format.
Thanks.
shanna_zhou
in reply to: lionSG
Thanks! It works.
I just feel wired that just some drawing of my project doesn't work for my way plotting project. Feel title block has some problem, but compare with other drawings, didn't find anything wrong.
Thanks for the solution.
Shanna
”Boost
