AutoCAD Electrical General
New Member
pwoodh
Message 1 of 2 (260 Views)
Scoot Aperture very small
260 Views, 1 Replies
08-20-2010 06:11 AM
I am trying to scoot some wire numbers, However when I action to scoot command, a very small box on the wire is displayed. I can scoot the wire, but the box is so small it can only just be seen. I thought that the box should encompass the wire numbers, but this does not seem to be happening. Think it may be something to do with the Poject configuration. I am only looking at the IEC4 libraries. Any help appreciated.
Active Contributor
Message 2 of 2 (254 Views)
Re: Scoot Aperture very small
08-20-2010 11:10 AM in reply to: pwoodh
The box the appears during the command is not unique to the scoot command, but is the generic AutoCAD 'selection' box or something similar.
Click the AutoCAD Icon in the top left of your window, and go into the AutoCAD options. I believe the setting you want to change is under the selection tab, but if not, it is in here somewhere. One of the options will show the selection cursor, and right below will have a slider to adjust its size.
A quick note; If you make the box to big, when you are zoomed out, the box will be big enough to select two wires, and odds are, it will always choose to scoot the one you didnt want to scoot.
Another note; scooting scoots wire numbers and wires separately, so if your box encompasses a wire and a wire number, it will be a toss-up as to which is going to be scooted.
You are not logged in.
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
